[BIETE] Titan Motorsports TRIPLE Fuel System mit 1200cc Injectors
Nagelneu und ovp, Kit besteht aus:
1 Titan Motorsports Fuel Rail
6 Lower intake manifold injector bungs
2 Fuel rail L brackets
2 Bolts-silver
2 Allen Bolts w/Teflon Nuts
2 Spacers that attach to bracke-cylinder shape
6 Injectors 1200cc
6 O-rings attached to injectors
6 Injector clips
1 Fuel Filter-Weldon WU1210
1 Custom fuel filter bracket
1 Triple Hanger
3 Walbro Fuel pumps GSS341
3 Fuel pump Set-up kits 400-762
1 Fuel Pressure Regulator-6 regulator
1 FPR Gauge-liquid filled
1 SS Line straight/straight -10 line long
1 SS line front rail straight/90 -8 line
1 SS line rear rail straight/90 -8 line
1 SS line 90/90 return line long
3 Rubber line for fuel pump
1 FPR AN Plugw/O-ring
1 FPR -6 fitting w/O-ring
2 AN-6/-6 fitting w/O-ring
2 AN -8/-8 fitting for fuel rail 2053
1 Y-adapter 1 -10 to 2 -8's
1 10 gauge wire, 33feet
1 10 gauge wire, 3feet
1 14 gauge wire, 3feet
1 Connectors for ground to bulkhead
3 Inline fuses
1 Electrical conector package
1 1/2" pipe to -9
1 1/2" pipe 90° to -10
1 3/8" pipe 90° to -11
3 Relays
3 Relay sockets
10 Zip-ties- small
1 Set of Instructions
Festpreis: 1875,- Euronen mit Versand
: 28. 08. 2013 [20:31]
