Warning: unlink(/var/www/vhosts/mkiv.de/httpdocs/typo3temp/Cache/Data/t3lib_l10n/7e82c85e166087f8c3d32d8dd2c081e5): No such file or directory in /var/www/html/typo3/typo3_src-4.7.18/t3lib/cache/backend/class.t3lib_cache_backend_filebackend.php on line 370
Warning: file_get_contents(/var/www/vhosts/mkiv.de/httpdocs/typo3temp/Cache/Data/t3lib_l10n/3d19e6bb73b03e03c73115eac51a241f): failed to open stream: No such file or directory in /var/www/html/typo3/typo3_src-4.7.18/t3lib/cache/backend/class.t3lib_cache_backend_filebackend.php on line 453
Fatal error: Uncaught TypeError: Argument 2 passed to t3lib_div::array_merge_recursive_overrule() must be of the type array, bool given, called in /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/cms/tslib/class.tslib_fe.php on line 4848 and defined in /var/www/html/typo3/typo3_src-4.7.18/t3lib/class.t3lib_div.php:1862
Stack trace:
#0 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/cms/tslib/class.tslib_fe.php(4848): t3lib_div::array_merge_recursive_overrule()
#1 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/cms/tslib/class.tslib_fe.php(4814): tslib_fe->readLLfile()
#2 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/cms/tslib/class.tslib_content.php(5461): tslib_fe->sL()
#3 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/cms/tslib/class.tslib_content.php(3582): tslib_cObj->getData()
#4 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/cms/tslib/class.tslib_content.php(3080): tslib_cObj->insertData()
#5 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/cms/tslib/class.tslib_content.php(1945): tslib_cObj->stdWrap in /var/www/html/typo3/typo3_src-4.7.18/t3lib/class.t3lib_div.php on line 1862
