Die Werte beziehen sich auf den Abstand zur Radnabe!
vorn: Vergleich zu den Originalen
................................Breite:....................................ET:...........................nach aussen:..........................nach innen:
meine:...................8,5J (21,59 cm)....................35.................................7,30 cm................................14,30 cm
original:.................8,5J (21,59 cm)....................50.................................5,80 cm................................15,80 cm
Differenz:.................0,0J (0,00 cm)....................15................................-1,50 cm.................................1,50 cm
vorn: Vergleich zu den Avs-Felgen
meinel:...................8,5J (21,59 cm)...................35..................................7,30 cm................................14,30 cm
Avs-Felgen:...........9,0J (22,86 cm)...................40..................................7,43 cm................................15,43 cm
Differenz:..................0,5J (1,27 cm).....................5..................................0,14 cm..................................1,14 cm
hinten: Vergleich zu den Originalen
meine:.....................9,5J (24,13 cm)...................35...................................8,57 cm................................15,57 cm
original:...................9,5J (24,13 cm)...................50...................................7,07 cm................................17,07 cm
Differenz:...................0,0J (0,00 cm)...................15..................................-1,50 cm ..................................1,50 cm
hinten: Vergleich zu den Avs-Felgen
meine:......................9,5J (24,13 cm)..................35....................................8,57 cm................................15,57 cm
Avs-Felgen............10,0J (25,40 cm)..................42....................................8,50 cm................................16,90 cm
Differenz:....................0,5J (1,27 cm)....................7...................................-0,06 cm...................................1,34 cm
Die Spalte nach aussen gibt an wie weit der äussere Rand der Felge von der Nabe entfernt ist.
Die Spalte nach innen wie weit nach innen.
Ist nach aussen negativ wandert das Rad nach innen, sprich es steht nicht soweit raus.
Ist nach innen negativ wird der Abstand zwischen Felge und Dämpfer/Feder größer.
Ich hoffe du kannst was damit anfangen. Die Differenz ist am ende entscheidend, wo deine Felge am ende abschließt im vergleich zu den Bildern.
