www.youtube.com/watch?v=kzyMNfqaVg8&feature=channel_page
hier isser auch nochmal in 8:15 um die nordschleife
www.youtube.com/watch?v=pimMAmznE3c
hier die specs:
Thanks for all the positive replies guys, i expected at least 1 or 2 wiseguys to say "the lambo driver wasn`t trying" ,
To answer a few questions,
Spec is phr2+ turbo running 520fwhp @1.4bar, was running 1.3 on the lambo session so around 500hp,
Nothing special in the suspension department, kyb agx dampers on j-spec springs with a decent geo setup.
I will update my garage and list everything else ive done.
When you say stripped out ive only changed my front seats and took out the backs but ive fitted a cage which must put the weight back in, i was running 1,3 bar so around 500fwhp (flywheelhorsepower, also motorleistung!!!).
zu den bremsen:
I am surprised the uks perform that well, you seemed to be out braking him most of the time, probably more to do with your driving technique though I guess..?
