HI Katrin
Can you please ask on the german forum what a supra RHD 1993 with 120 kilometers and the following spec is worth? All mods are no more than 4 years old, much including turbo and diff etc are brand new. approx 700bhp.
Engine Block
Carrillo H section Rods,
SP Carr Rod Bolts
CP Forged Pistons 86.5mm
Uprated wrist pins
Lightened / Balanced & Bladed Crankshaft
Lightened Race Dampened BL Crank Pulley
Power Enterprise Cam Belt
Modified Oil Pump
New Water Pump
Unorthodox Racing Accessory Pulleys
TRD Engine mounts
Cylinder Head
Cylinder Head Race Ported & Polished
Ferrea valves 1 mm over sized
Crower Uprated springs
Crower Titanium retainers
HKS 256 inlet Cam
HKS 264 exhaust cam
HKS Cam Pulleys
Greddy 2mm Head Gasket
ARP Head Studs
Transmission
6 Speed Getrag Gearbox
RPS Lightened Segmented Flywheel
RPS Carbon twin plate clutch
UK rear diff (For more top end) Torsen LSD.
TRD Gear Box mounts
NEW TRD LSD
Fuel System
Siemens 850cc injectors (fully flow balanced)
Boost Logic fuel rail
2 x Walbro intank pumps
Aeromotive fuel pressure regulator
2 x -6 braided fuel lines
2 x stock filters
Turbo System
4" Custom Cold Air feed/filter.
New Sound Performance HKS Style Stainless Manifold
New Garrett GT4088R Black Chrome
PHR 3" IC pipework ( 4 row style)
1 x Blitz BOV
1 x HKS SSBOV
HKS GT wastegate (60mm)
New Super dragger Exhaust
Modified HKS Throttle body
Modified Intake Manifold
GReddy IC Pipe with dual injector bosses
Cooling
HKS R Type FMIC
FMIC Carbon Cover plate
Mocal Oil Cooler
Thermostatic High Flow Sandwich plate
ERL Water/Methanol Injection System
Fluidyne Radiator
S/S Radiator cover
TRD Thermostat
PAS Cooler
Electronics:
Autronic SM2 Stand Alone ECU with gear selectable & programmable traction control
Complete F1 spec loom
Autronic 500R Cdi ignition system
NGK IX plugs
BLITZ SBC ID II
Blitz Power Meter
Spa Oil Temp/Pressure Gauge
AEM WBo2 Gauge
Suspension and Wheels
Full JIC Magic FLT-A2 aluminium bodied Coil Overs
Pillow Ball Mounts
Whiteline race anti roll bars and bushes
Cusco front strut brace
Antera 309 wheels
DO Luck 4 point rear brace
Brakes
UK 4pot/2pot Calipers
New Carbotech XP+ Pads
New DBA 4000 XS Discs all round
Exterior
Quicksilver
Faceleift front
carbon front lip colour coded
TRD Style wing vents
OEM Sideskirts
OEM Rear Spats
RMM rear spoiler with Carbon Insert
New UK spec healights and HID
Interior
Black Leather
NEW TRD Steering Wheel
Toyota alloy pedal covers
Wer will zur JAE in England?
Da wo sich Dutzende von Supras jedes Jahr treffen?
Weitere Infos bei mir per PN!
