Find den Blitz FATT DC III am interessantesten weil er die "intelligentesten" Nachlauffeatures hat. Die hat nur der Blitz.
www.suprastore.com/blitturtimwv.html
Features:
Manual Timer - Allows the user to preset count down time.
Automatic Timer - The FATT DC III has the ability to calculate the count down time by the how the vehicle was driven. There are 5 different types:
A-L - will start to calculate time automatically after 1800rpm. Low setting
A-S - will start to calculate time automatically after 1200rpm. Medium setting
A-H - will start to calculate time automatically after 900rpm. High setting
E-L - will start to calculate time according to how long the ignition has been on. Adds 55 seconds per hour.
E-H -will start to calculate time according to how long the ignition has been on. Adds130 seconds per hour.
Voltage Display - The FATT DC III has a built in voltage display. This allows the user to monitor the vehicle's charging system.
Temperature Display - The FATT DC III also has a built in air temperature display. This allows the user to monitor the cabin temperature.
Stop Watch and Lap Timer - This unique feature allows the user to use the stop watch function and also can record up to 5 lap times.
Adjustable Display - This turbo timer can also allow the user to adjust how the bar display moves. There are 4 different display types, one moves according to throttle and the others are programmed movements.
Adjustable Contrast - Allows the user to adjust the contrast setting.
Zeichentrickfreak
