info dazu:
A Disk is our standard disk type. It has moderate amount
of brake clearance, fits over most OEM brake calipers. It
offer moderate amount of lip. A disk option is available on
all WORK two and three piece wheels.
O disk is designed mostly for rear wheel use. Noticed the
curvature of the spoke is slightly less then A-Disk and the
hub area is slightly thinner. Since spoke curve is less then
A-Disk, then the center disk will appear to be flatter and
allow more lip to be exposed, but this give the wheels
least amount of brake clearance. O disk is available on all
L,R,T disk are all big brake caliper disks. These are
designed for BBK application or OEM vehicle with larger
size brake calipers. Noticed the curvature of the spoke is
much more then A and O disk thus to create more room for
brake caliper, but very little lip shown. Almost all WORK
two and three piece wheels are available with R disk
option.
Aber es wird nicht klar Defeniert was genau besser schlechter ist?? o.O
#BUILD UP
