3,4l stroker
Titan Motorsports releases 3.5L 2JZ Stroker Kit
Taking the old hot rod statement "There's no Replacement for Displacement" to heart, we went to work and developed a new 3.5L stroker kit for the 2JZ. Increasing the factory displacement by .5L to increase low end torque and horse power and reduce turbo lag. Using one of our Titan Motorsports True Billet Crankshaft designed for our 3.5L, we increased the stroke by 10mm to 96mm, increasing the displacement to 3.5L. The Titan Motorsports 3.5L Billet Crankshaft also features a 1.88" rod bearing which allows a wider range of bearing options as well as a larger variety of bearing materiel availability over factory sized Toyota bearings. The Billet Crankshaft is complimented by Custom Titan Motorsports / CP Pistons in 87mm bore, and Custom Titan Motorsports / Carrillo H-Bream connecting Rods with Upgraded Rod Bolts both built to our specifications. The recommended maximum RPM limit for this kit is 9,000 RPM when combined with proper camshaft selection and a lightweight valve train.
http://ep.yimg.com/ca/I/titanmotorsports_2213_1157683
: 17. 07. 2012 [15:20]
OK Paul
: 17. 07. 2012 [15:25]
