Warning: file_get_contents(/var/www/vhosts/mkiv.de/httpdocs/typo3temp/Cache/Data/t3lib_l10n/ec6b09e4a3f8e8b8c7455d8cd7ef8e95): failed to open stream: No such file or directory in /var/www/html/typo3/typo3_src-4.7.18/t3lib/cache/backend/class.t3lib_cache_backend_filebackend.php on line 453
Warning: unlink(/var/www/vhosts/mkiv.de/httpdocs/typo3temp/Cache/Data/t3lib_l10n/2f17e512a4edba1cb4fc76a7acc8bc1d): No such file or directory in /var/www/html/typo3/typo3_src-4.7.18/t3lib/cache/backend/class.t3lib_cache_backend_filebackend.php on line 370
Fatal error: Uncaught TypeError: Argument 1 passed to t3lib_div::array_merge_recursive_overrule() must be of the type array, bool given, called in /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/lang/lang.php on line 529 and defined in /var/www/html/typo3/typo3_src-4.7.18/t3lib/class.t3lib_div.php:1862
Stack trace:
#0 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/lang/lang.php(529): t3lib_div::array_merge_recursive_overrule()
#1 /var/www/html/typo3/typo3_src-4.7.18/typo3/sysext/lang/lang.php(351): language->readLLfile()
#2 /var/www/vhosts/mkiv.de/httpdocs/typo3conf/ext/ratings/class.tx_ratings_api.php(229): language->sL()
#3 /var/www/vhosts/mkiv.de/httpdocs/typo3conf/ext/ratings/class.tx_ratings_api.php(109): tx_ratings_api->generateRatingContent()
#4 /var/www/vhosts/mkiv.de/httpdocs/typo3conf/ext/mm_forum/includes/class.tx_mmforum_base.php(646): tx_ratings_api->getRatingDisplay()
#5 /var/www/vhosts/mkiv.de/httpdocs/typo3conf/ext/mm_forum/pi1/class.tx_mmforum_postfunctions.php(596): tx_mmforum_base->getRatingDisplay in /var/www/html/typo3/typo3_src-4.7.18/t3lib/class.t3lib_div.php on line 1862
