Pistons
STOCK - 86mm / 8:5:1 / Piston 407g / Pin 132g / Rings / Clips / Total Weight
Mahle - 86.5mm / 8:5:1 / Piston 319g / Pin (.197" Wall) 103g / Rings 20g / Clips 2g / Total Weight = 444g
Manley - 86.5mm / 8:5:1 / Piston 355g / Pin (.150" Wall) 106g / Rings 20-25g / Clips 2g / Total Weight = Approx 485g
Probe - 86.5mm / 8:5:1 / Piston 335g / Pin (.126" Wall) 65g / Rings 20-25g / Clips 2g / Total Weight = Approx 425g
Wiseco - 86.5mm / 8:5:1 / Piston 334g / Pin (.157" Wall) 112g / Rings 25g / Clips 3g / Total Weight = 474g -or- 494g w/.197" Pin Upgrade
Arias - 86.5mm / 8:9:1 / Piston 355g / Pin / Rings / Clips / Total Weight
JE - 86.5mm / 8:5:1 / Piston 330g / Pin / Rings / Clips / Total Weight
Toda - 86mm / 8:6:1 / Piston / Pin / Rings / Clips / Total Weight
HKS - 87mm / Comp? / Piston 384g / Pin 112g / Rings / Clips / Total Weight
CP - 86.5mm / 8:5:1 / Piston 322g / Pin / Rings / Clips / Total Weight
Crower - 86.5mm / 8:5:1 / Piston 338g / Pin / Rings / Clips / Total Weight
Titan Street - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
Titan Ultimate - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
Titan Billet - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
Greddy / Grex - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
Tomei - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
JUN C Series (Cosworth) - 87mm / Comp ? / Piston 343g / Pin 104g / Rings / Clips / Total Weight
JUN W Series (Wossner) - 86.5mm / 8:0:1 / Piston 362g / Pin / Rings / Clips / Total Weight
Arias 86.50mm 355g
Arias 87.00mm 362g
CP 86.50mm 322g
Crower 338g Bore: 3.405, +.020 - Comp: 8.5:1
HKS 87.00mm Forged 384g Pin 112 Grams
JE 86.50mm Forged 330g na
JE 87.00mm Forged 333g na
JUN C Series (Cosworth) 87.00mm 343g Pin 104 Grams - Cosworth part# PA1737
JUN W Series (Wossner) 86.50mm 362g OE Comp 8.5:1 - Wossner Comp 8.0:1 - Wossner Part# K9057D050
JUN W Series (Wossner) 87.00mm 362g OE Comp 8.5:1 - Wossner Comp 8.0:1 - Wossner Part# K9057D100
Mahle 87.00mm 332.5g Pro Series Pistons
Stock 86.00mm 407 Grams
Rods
STOCK = 761g with OEM Bolts
K1 = 562g with 3/8" ARP2000 / Approx 566g with 3/8" Custom Age 625 / Approx 568g with 3/8" MP35N (like Carrillo's "Carr"
Manley H Beam = 552g with 3/8" ARP2000 / Approx 556g with 3/8" Custom Age 625
Manley Turbo Tuff = 705g with 3/8" ARP2000 / Approx 709g with 3/8" Custom Age 625
Brian Crower Pro Series = 608g with 3/8" Custom Age 625
Carillo A Beam = 524g with 3/8" WMC
Carillo SA ?? = 569g with 3/8" WMC
Carillo H Beam = 600g with 3/8" Carr / 595g with 3/8" WMC
Carillo H Beam HD = 606g with 3/8" Carr / 601g with 3/8" WMC
Eagle ESP = 590g with 3/8" ARP2000 / * People always mention L19 bolts, but Eagle told me L19 is NOT an option on the Supra, only on domestics.
Crower I Beam = 552g with ?
Crower Titanium = 392g with ?
HKS = 594g with ?
Pauter = 680g with 3/8" ARP2000
Pauter Titanium = ? with 3/8" ARP2000
Brian Crower I Beam 495g Bolt 57g
Carillo H beams 580g
Carillo incl bolts 602g
Crower Titanium 392g
Eagle 594g
Pauters 680g
Stock Rod stripped 761g
Stock Rod with bearing 800g
Stock Wrist Pin 132g
