Blitz MK4 auf dem Nürburgring
Amtrack
: 26.01.2007
: 8
Habe in der Suche nichts entsprechendes gefunden, ich hoffe es war nicht schon einmal da.
www.dpccars.com/car-movies/07-03-06pageBlitzToyotaSupraatNurburgring.htm[/url]
und ein paar Daten zum Wagen
eepSkyBlue">BLITZ TOYOTA SUPRA TURBO SPECIFICATIONS
Engine:
3068cc straight 6-cylinder, 24 valve, twin-cam, twin-turbocharged, 1.8mm metal head gasket, Kolben Schmidt pistons, H-section conrods, balanced crank, Blitz Access engine management system, lightweight racing battery, NGK no 10 racing plugs, valves and ports polished, KKK K26 turbos, Blitz-type RC wastegates, Blitz B-type intercooler, A-type Oil cooler and power steering cooler, Blitz prototype radiator, twin Bosch 240-litre fuel pumps, NISMO (Nissan Motorsport) single 2.7kg/cm squared fuel regulator, Blitz 850cc side-feed injectors. Racelogic traction and launch control, Blitz 42.7mm stainless manifold, 60mm twin- tube and 100mm Silencer with 130mm outlet.
Transmission:
Getrag 6 speed gearbox, triple plate clutch with lightened flywheel, Blitz prototype diff cooler, final gear ratio 3.588, TRD (Toyota Racing Development) transmission bushes.
Suspension:
Front - double wishbone with Sachs two-way damper and Eibach co-axial spring (rated - 18kg)
Rear - double wishbone with Sachs two-way damper and Eibach co-axial spring (rated - 12kg)
Toyota original anti-roll bar, TRD rear subframe bushes, Blitz prototype top mounts.
Brakes:
Front - Brembo Ferrari F0 setup consisting of ventilated 332mm discs (35mm thick)
Rear - Toyota standard 320mm discs (28mm thick)
PFC carbon metric pads all round.
Wheels and Tyres:
Front - Blitz Z-1 9x18" split-rims with 245/40 ZR Dunlop W-10 tyres
Rear - Blitz Z-1 10x18" split-rims with 265/35 ZR Dunlop W-10 tyres
Bodywork:
Blitz front/rear bumpers, side skirts, adjustable rear wing and lightweight doors, TRD vented bonnet.
Interior:
Stripped out with Blitz-Konig RS-2000 carbon/kevlar buckets, Sabelt harnesses, Heigo 4 point rollcage with side bars, TRD steering wheel, additional boost, oil and water temperature gauges (all Blitz).
Performance:
Max Power - 750bhp at 5900rpm
Max speed is 200+mph
0-60mph in under 4 secs
0-125mph in under 10 secs.
Man braucht nur zwei Werkzeuge: WD-40 und Panzerband. Wenn es sich bewegen sollte, es aber nicht tut, benutze WD-40. Wenn es sich bewegt, es aber nicht sollte, benutze Panzerband... grin.png
: 14. 05. 2008 [17:19]
Supraholic330
: 22.02.2008
: 683
Cool, kannte ich noch nicht.
Wäre interressant was ein richtiger Nordschleifen-Profi für ne Zeit mit dem Ding fahren würde.
: 14. 05. 2008 [18:42]
Mit den geplanten 1100 kg dürfte eine gute Zeit nicht schwer sein.
: 14. 05. 2008 [18:51]
asbach uralt sag ich da nur
: 14. 05. 2008 [21:04]
MAF
: 13.12.2005
: 61
Wurde vor ein paar Jahren bei Ebay UK versteigert, in der Artikelbeschreibung stand es wäre das original 7.49er Nürburgring Fahrzeug.
: 15. 05. 2008 [08:29]
