Ein weiterer Supra aus der Türkei
http://www.yukleresim.com/images/68956867867342708347.jpg
http://www.yukleresim.com/images/99507074865461357402.jpg
http://www.yukleresim.com/images/55656603213281541957.jpg
http://www.yukleresim.com/images/81806993243361505448.jpg
http://www.yukleresim.com/images/38202681983835887054.jpg
http://www.yukleresim.com/images/62251587906013344691.jpg
http://www.yukleresim.com/images/38735986197549833272.jpg
http://www.yukleresim.com/images/00245145451690731357.jpg
http://www.yukleresim.com/images/73438326618128034534.jpg
http://www.yukleresim.com/images/72786199256199311632.jpg
http://www.yukleresim.com/images/77320329154890336544.jpg
http://www.yukleresim.com/images/27953805997345144459.jpg
http://www.yukleresim.com/images/67719769665051451671.jpg
http://www.yukleresim.com/images/80854863110964881453.jpg
http://www.yukleresim.com/images/17163117382972020422.jpg
http://www.yukleresim.com/images/76397179609393077049.jpg
http://www.yukleresim.com/images/76613341656206177996.jpg
Und der erste Start nach der Fertigstellung...
www.streetfire.net/video/supra-first-start-sup40_2059398.htm
Motoraufbau und Einzelanfertigungen etc von Peak Garage
AEM Programmierung von OZ ECU(der dickerchen im Videoicon_biggrin.gif)
Ein Auszug aus der Teileliste
-Titan billet main caps
-ARP main studs
-Carillo H beam kollar
-Titan motorsports Custom piston set
-ARP 1/2" bolts
-Power enterprise Rod bearings
-Boostlogic Headgasket
-Ferrea Competition Plus Valves
-Ferrea Valve Springs
-Ferrea Titanium Retainers
-Ferrea Spring Seat Locator
-Ferrea Valve Locks
-Ferrea Valve Stems Seals
-HKS Cam Gears
-HKS 264 Camshafts
-HKS Timing Belt
-Titan Motorsports Billet Timing Belt Tensioner
-Greddy Pulley Set
-Greddy Ansaugbrücke
-Hypertune 90mm Drosselklappe
-Fullrace turbo manifold
-Garrett bb gt4094 t4 divided turbo. ( nach der auto2manual swap soll es auf gt42 od 45 gehen)
-Boostlogic Supra TT Oil Feed and Return Kit
-Titan motorsports triple fuel pump system
-HKS oil cooler
-HKS hypermax coilover set
-AEM Water Methanol Injection Kit - 5 GAL
-Boost Logic Torque Converter by 3800 Stall
-Spal 7.5" Pull Fan For Auxillary Cooler
-9 Passage Transmission Oil Cooler 18x8.75x1
-R2 Racing Front Control Arm Bushing Kit
-R2 Racing Rear Control Arm Bushing Kit
-Samco Hose Kit
-TRD Low Temp Thermostat
-Koyo Radiator 53mm
-AEM 5 Bar Map Sensor
-AEM Intake Temp Sensor
-AEM EMS Gen 2 Ecu
-AEM Wideband
-HKS DLI
-HKS Radiator Cap
-MVP Motorsports Lexan Spark Plug Cover
-TRD Motor Mounts
-TRD Oil Filter Cap
-TRD 10,000 RPM Tach
-TRD 320 km/h Speedometer
-TRD LSD w/Installation kit and all Bearings need
: 21. 09. 2010 [19:35]
