Noise coming from the back
Mikzu IV
: 20.10.2005
: 148
It's been nerving me for a year now, every time I hit a bumb there is a noise comming from the back, like something was loose. it doesn't come from the inside, and it's not the tail gate.
What could it be?? :unsicher:
MY TOYOTA IS FANTASTIC
http://www.supraclubfinland.com
: 03. 09. 2006 [21:00]
aemkej
: 05.03.2006
: 367
Well... There's actually not too many things to be taken into consideration. Maybe the mounting of the exhaust? Is it certain it is not coming from the inside?
: 04. 09. 2006 [07:54]
Mikzu IV
: 20.10.2005
: 148
I dont think it's the exhaust, cause it makes the noise also with the original exhaust. I would say the noise is comming from the right, back corner.
I still need to see if it's not comming from the inside of the tail gate's plastic panel. I have taken every other panel away form the back but I found nothing suspect.
I have already changed the rubber bumpers for the tail gate.
I was also by the local ACL (adac) and they checked it out and said to me that the sway bar's fixation is loosing oil grin.png grin.png
: 04. 09. 2006 [08:34]
aemkej
: 05.03.2006
: 367
Well, that's odd. I've been harrassed by the tools and the styrofoam they've put around the spare-wheel well. But that indubitably comes from the inside.
How exactly does that noise sound? I reckon it's some kind of tictacking? Or maybe a rather squeaky noise? Have you had a look under the car at the suspension?
: 04. 09. 2006 [09:41]
Mikzu IV
: 20.10.2005
: 148
The sound is the same like when you hit slowly a wooden table with a spoon grin.png
and this 2-3 times always when you hit a bumb on a normal street.
Yeah the mecanicians took a look under and found nothing.
I've been under also and everything seemd to be tight.
All my tools and spare wheel are tight too.
Thanks.
: 04. 09. 2006 [10:20]
McMsk
: 25.04.2005
: 223
I'm quite sure it's the rubber dampers of the trunk lid. Look if they are cracked,, if they are, it is certainly them.
: 04. 09. 2006 [18:14]
Mikzu IV
: 20.10.2005
: 148
Thanks
: 04. 09. 2006 [18:56]
